Re: F20 Sleeves Pistons
Posted by Skaning on August 04, 2009 at 21:04:48 from (12.189.32.37):
In Reply to: F20 Sleeves Pistons posted by Farmall 47 on August 04, 2009 at 18:57:23:
It will be a challenge to get new ones. I needed a set for my regular (same engine). Not that the piston/ sleeve fit was all that bad, it had just rusted so badly at the block sleeve interface it seemed unlikely that we could get by without a coolant leak. There were a ton of suggestions including JB weld. I finally found a NOS set of sleeves and pistons at Alderson. Rice didn"t have any and Fordson only had used ones. The used ones unfortunately had the same corrosion issues mine had.
Not cheap but he had them and the price wasn"t far off from having a set of sleeves made. At the time he also had some oversize sets.
Any new ones will probably have to be obtained from a sleeve house like LA Sleeve. There are several on the internet. Quote I got from LA sleeve was about 250 each.
Send them yours and they will duplicate it. Chances are your piston isn"t that worn so the new sleeves can be fitted to them and a set of rings will get you on your way.. Oddly, rings are available.
Good luck
Skaning
Today's Featured Article - More Memories of a Field Service Engineer - by Brian Dye. Introduction: The author worked for one of the largest Ford tractor dealerships in England as a trouble-shooter on tractor engines, hydraulics and combine harvesters from 1963 to 1972. In 1972 he became a dealer manager and finally left the dealer net in 1975 to run his own electronic design and manufacturing company. [Editor] We live right in the middle of Norfolk. The dealership that I worked for sold Fordson Tractors from the 1920's and some of t ... [Read Article]
