Re: SMTA may be stuck...
Posted by El Toro on July 30, 2009 at 07:10:15 from (64.12.116.73):
In Reply to: SMTA may be stuck... posted by mike sdak on July 29, 2009 at 16:45:07:
I used ATF back in 1975 on a Farmall A that was stuck. You should pull all the sparkplugs to make sure there's no water on top of the pistons then see if you can bump over the engine with the starter. If you can find a borescope light and take a peek in the cylinders you will be able to see how rusty they are. You can always pull the head and set each cylinder on fire using kerosene
or diesel fuel. Don't do this near any building
and remove anything flammable. Hal
Today's Featured Article - Old Abe is Still Making Hay - by Jeremy Sweeten. Things have changed a bit since my last article. I am now almost finished graduate school at Purdue University. I am still in Agronomy, but specializing in hay and forages. My wife has survived two years of marriage to a part-time farmer. The equipment line up has changed a bit too. The DC has retired to ... [Read Article]
