Posted by SDE on July 29, 2009 at 17:06:05 from (174.124.30.29):
In Reply to: SMTA may be stuck... posted by mike sdak on July 29, 2009 at 16:45:07:
Our local rifle club had a "H" and it froze up over one winter. It was left out and the snow would melt on the muffler and run down into the intake. The pipe was broken and and that is all it took.
Automatic transmission fluid is about the best for loosening the engine, if it is the rings stuck to the sleeves. Drain the oil from the pan. Remove the spark plugs and put some in each cyclinder. After about a week check to see if the ATF is in the oil pan. If it is, use a stiff wire as a dipstick and check each cyclinder. If they are drained down then try to roll the engine over either with the starter or by rocking it while the tranny is in high gear. It might take a couple of weeks to free up. Good Luck Steve
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the
... [Read Article]
Latest Ad:
Late 50s early 60s international harvester 560 with cultivator
[More Ads]
