Re: 656 draft control reassembly
Posted by karl f on July 20, 2009 at 15:13:53 from (209.188.106.159):
In Reply to: Re: 656 draft control reassembly posted by Allan In NE on July 20, 2009 at 12:02:31:
Allen, thanks for the clarification of your terminology. I would prefer to call that a (tall) plug, and the tube in the rear the standpipe, as the tube in the rear is a drain pipe and is also the device keeping the oil level so high.
I am still uncomfortable removing the front drain plug until i know more about the overflow plumbing to the differential and suction tube.
I have no problem removing the drain tube in back if it is removable since the oil will still all go where it is supposed to, and at a much lower oil level.
I would guess i get caught up in details sometimes!
karl f
Today's Featured Article - Tractor Generators - by Chris Pratt. As a companion to the articles on three-brush and two-brush generators, it seemed fitting that we should provide our readers with a description of how a generator works in lay terms. The difficulty with all those "theory of operation" texts is that they border on principles of electricity or physics and such. Since I know nothing of either, you will have to put up with looking at the common sense side of how generators work which means we " ... [Read Article]
