locked up Super C water pump.
Posted by Andrew Kappers on July 13, 2009 at 17:09:59 from (67.55.184.219):
I was running the super c last weekend when I all of a sudden noticed a bunch of black smoke coming from the front end of the tractor. I shut it down right away and looked at the front end and didnt notice anything unusual. I started it again and it had black smoke again. I got off and looked and shur enough the belt was just burning on the water pump pulley. Water pump wasnt turning. Took about an hour to tear into it and finally got the water pump off. When I looked at it, the probeler was wedged and kind of bent to one side. I thinking the bearing went out. Is this a huge thing. Should i rebuild the old or buy new. Thanks for the help. Andy
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
