Re: McCormick-Deering 10-20 Carburater guidance
Posted by dave.koenigsfeld on July 01, 2009 at 17:53:03 from (148.78.54.134):
In Reply to: Re: McCormick-Deering 10-20 Carburater guidance posted by Bob Kerr on June 30, 2009 at 20:50:38:
Bob - do i use the top of the float at the line or the bottom of the float?
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
