584 IH hydraulic problem
Posted by ForeverYoung on May 31, 2009 at 16:47:03 from (71.53.193.177):
The rear lift and remotes will quit after the tractor is used for a few hours, then works fine after a short cooling off period. It doesn't do it every time it's used but fairly often. Power steering still works just fine. Any ideas?
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
