Posted by bc on May 19, 2009 at 15:23:06 from (69.148.27.75):
In Reply to: 706 dies posted by BobIa on May 19, 2009 at 06:46:50:
Just as well pull the fuel line and run it into a gas can. Should have good flow for at least 5 minutes. Drain the gas. Pull the sediment bowl and then flush the tank. As old as the 706 is, it probably has big chunks of rust or a leaf up there.
If rust, you can acidize the tank. Ask later or check the archives here about that. Then get a piece of 1 inch or two or so fuel line or plastic line that will fit over the sediment bulb stub that sticks up into the tank. That will keep the bottom dwelling crud and water from getting into the fuel. 2 or 3 wraps with window screen sticking up into the tank a couple inches and wire tied at the around the stub will work too.
Post back with what you find out. Running down the road in road gear hitting all those bumps is moving all that rust and crud around. You may get good flow with the tractor sitting or running steady in a field but I'd bet your farm there is rust in there.
I replaced my solenoid with a regular jet, nut, and packing. Now I have an adjustment if I ever need it.
When you pull you sediment bowl, you might think about adding a quarter turn plumbing valve from the hardware store with a couple brass nipples. I acidized my tank but still had rust come back so I added a drip leg like used with natural gas going into a furnace or water heater. Came off the drip leg with a tee and then added the sediment bowl. Since the sediment bowl shutoffs don't close half the time, I added the plumbing valve after that but it might have been better to put it before.
Today's Featured Article - The David Brown Rose Badge - by Samuel Kennedy. In the 13th century civil war was raging in England. Two English noblemen were involved in a conflict which became known as the War of the Roses. The Duke of York had as his emblem a white rose and the Earl of Lancaster had a red rose. Today the white rose is the official emblem of the county of Yorkshire and the red rose has been adopted by the neighboring county of Lancashire.
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
