Posted by Janicholson on February 26, 2009 at 17:02:32 from (64.83.225.108):
In Reply to: farmall h hole in rear posted by s.gross(in pa) on February 26, 2009 at 16:54:01:
If it is repaired and the tractor operates good. if not, and the rest of the tracctor is good to better, no issue. A bearing came apart in the rearend. Or the pinion bearing carrier was attempted to be removed W/O pulling the bull gear out of the way. Pieces of metal wedged between the Bull and case with the weakest part (case) exploding outward. Many are that way without issue. JimN
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
