Re: 1940 M
Posted by D Slater on February 04, 2009 at 07:14:58 from (71.164.55.189):
In Reply to: 1940 M posted by Mike Schwartz on February 03, 2009 at 20:29:53:
serial # 9286 was the last with slot top. Does the engine have a cast # 365586 R1, or is it ground off, or ground off and a # stamped in? Does it have a cover plate on side of block near carburetor with 2 bolts holding plate to block? Maybe a dipstick or dipstick hole pluged versus never drilled? If block actually has C-248 cast on block, that and all above could indicate a replacement block.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let�s make one more addition to our series on hydraulics. I�ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
