Re: Farmall C engine temporary lock up
Posted by James Williams on January 31, 2009 at 16:22:11 from (65.73.216.19):
In Reply to: Farmall C engine temporary lock up posted by SDP1 on January 31, 2009 at 08:57:06:
SDPI,Be careful braking a starter loose with a crank,I broke a starter drive on a F14 this way,However it sounds like you need a drive any way
jimmy
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c ... [Read Article]
Latest Ad: John Deere 750 Diesel Yanmar J80TU engine. pistons and rings replaced when discovered crankshaft was bent. 3995 OBO Pictures available upon request [More Ads]
