Re: converting H to 3point hitch W /hydraulics
Posted by Bob Kerr on January 10, 2009 at 21:58:39 from (63.134.174.169):
In Reply to: converting H to 3point hitch W /hydraulics posted by welderdave on January 10, 2009 at 13:41:14:
I will second the Saginaw hitch being a good one. I have an H also and put one on it. I just run it 1 way and have no problems unless the oil in the pump is very cold it is slow to go down. If I lift some heavy logs it will warm up though. With the 2 cyls it won't twist the pivot bar like can happen with single cyl types. I also have an M that has an old aftermarket 1 cyl 3 point and 2 way and it could be a real pain on uneven ground/ I turned the bushog into a rotary tiller several times and bent the mower hitch. It also made grading a tough job with constant adjusting. The Saginaw hitch does have a float abillity but since I am only running 1 way I haven't needed it yet. As far as the belly pump goes, there was 2 pressures availible one as an option or upgrade kit I think was something like 800 or 900 psi and the factory one was about 500-600 or there abouts. Not sure which one I have, but it will lift a bunch with the boom pole and pick the front wheels of the tractor off the ground with real big logs. I haven't had a need for a reservoir yet but if you use a loader or something like that you might need one.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
