If by bracket, you mean the holes on each side at the bottom of the housing, those accepted curved rods that ran up to the hydraulic cylinders. We used them to lift a semi-mounted plow. There is no reason to use that setup on a three point if that is what you mean. Put the cylinder on the 3 point and run a hose to it. The rods were for a lifting mechanism and were not made to pull a load of any kind. I assume you do not mean a heavy duty bracket attached to the sides of the clutch housing, not to the belly pump--that was used to do the main pulling of the semi-mount plow.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
