Re: B axle removal
Posted by Gene Bender on January 06, 2009 at 21:11:41 from (67.55.226.75):
In Reply to: B axle removal posted by Kevin Wieber on January 06, 2009 at 18:08:05:
When you pull the drop housing the differental shaft will come along. You dont need to remove the pto assy. To remove the shaft after the drop housing is removed you need to remove the brake drum then the shaft will come out thru the drop housing by removing the little cover.The shaft will not go out towards the tranny end.
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
