Posted by Janicholson on November 29, 2008 at 20:50:40 from (209.191.204.206):
In Reply to: Farmall 400 no spark. posted by Kelly C on November 29, 2008 at 19:40:02:
Pull the coil to destributor "Small" wire off of the terminal on the destributor. Pull the coil wire (high voltage) out of the center of the dist. cap, and place it so it is 1/4 " from the cylinder block. (put it in neutral) Turn on the ignition, and ground the wire you took off of the distributor terminal. Pull it off of ground and watch for spark. this replaces the points with momentary contact to ground. If it does not spark (both places) the coil is either not getting voltage, or it is bad!! If it works, the distributor is not operating correctly. Put an ohm meter on the terminal (withno wire on it) and to ground. With the points nopen, there should be infinate resistance. With the points closed, there should be no resistance. Good luck, JimN
Today's Featured Article - Tractor Profile: Case VA Series - by Staff. V, VC, VI and VO). Althouh the Case VA looked much like the V, it shared no major components with its predecessor. Except for military units, the production of the Case VA was interrupted in July of 1942 due to World War II. It resumed again in 1944 and continued until 1953. It started up briefly later on in 1953 and continued on a very limited basis until 1956. The VA Series included the following models: VA: Fixed front wheel tread VAC:
... [Read Article]
Latest Ad:
Massey Ferguson model 65 diesel tractor
[More Ads]
