Hello John, sounds like your fuel is bleeding back or you are getting air into the fuel system. I am not sure how the fuel system is set up on a 364. if the tank is lower then the pump and you have a loose line you could get air in the fuel. you could try bleeding it before you start it with the hand primmer pump. or park it on a hill so the fuel level is above the injection pump and see what happens. Good Luck Ed
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th
... [Read Article]
