Re: diesel 364 trouble starting
Posted by LMack on November 28, 2008 at 16:56:05 from (74.224.200.230):
In Reply to: diesel 364 trouble starting posted by john in pennsylvania on November 28, 2008 at 16:19:27:
Can you tell if you get blue oil smoke when you first start it up? It sounds like you may not have quite enough compression on starting and it gets better when the rings get hot. If it were a problem with the injectors, it would not clear up when you get it started. You might want to run a compression test. If the main seal was so worn that you had to replace it, the entire engin may be well worn. In any case, diesels can be a booger to start in cold weather.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
