Posted by hayfarmer on November 19, 2008 at 12:42:12 from (66.243.237.36):
In Reply to: SMTA TA problem posted by GordoSD on November 19, 2008 at 11:01:26:
If it is slipping on the "low side" it is probably ramps and rollers. You said it was reassembled , did you work on TA? You can put it in a higher gear and hold the brakes to see if it will slip. Usually if it is ramp and roller problem it will start slipping in higher gears then work down, generally when you have a load on it. If it slips on the "high" side it is usually caused by the clutch. Clutch is about all you can see from the top.
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos
... [Read Article]
Latest Ad:
[More Ads]
