Re: Throw-out bearing on an M - is it a problem?
Posted by Bob M on November 11, 2008 at 11:12:35 from (151.190.254.108):
In Reply to: Throw-out bearing on an M - is it a problem? posted by Slappy on November 11, 2008 at 10:26:51:
1 - When the clutch is disengaged the throwout exerts several hundred pounds of force on clutch fingers. That more than enough friction between the fingers and the bearing rotating memeber to overcome initial stiffness in bearing.
2 - Once the bearing is installed then the clutch has been disengaged a minute or two with the engine running, the bearing should loosen up considerably as the lubricant gets churned up and "rearranged" within the bearing.
So long as bearing can be turned at all before it's installed I wouldn't be too concerned.
Today's Featured Article - The Day Mom Drove the 8N - by Brian Browning. My Dad was wanting to put in a garden but couldn't operate the 8N and handle the old horse drawn plow he had found and rigged up to use with the tractor. Well, he decided to go get Mom out of the house and have her drive the tractor while he walked behind the plow. You got to understand that while my Mom is a hard worker who will always help whenever she can... she had never operated farm machinery before that day. Dad got her out there, explained how the clutch was the same as in our o ... [Read Article]
