Farmall c Won't shut off
Posted by c_man on October 12, 2008 at 13:20:02 from (216.249.80.233):
I just Finished a complete overhaul on my 1950 Farmall c. I used 1/8th inch overbore sleeves and step pistons. After I shut it off it keeps running very rough and slow. The engine is"t even hot yet. I know there is no carbon build up it is all new. Could timing cause this, or is the fuel/air mix too rich, or do I need to get a higher grade fuel?
Thanks.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
