Re: farmall h valve guide seals
Posted by MN Scott on October 06, 2008 at 20:27:40 from (206.9.216.36):
In Reply to: farmall h valve guide seals posted by pgo12 on October 06, 2008 at 14:34:25:
I don't use them on gas tractors that are worked. I like a little oil in the guides to help keep the wear down. If the guides and valves are in spec you will burn very little to no oil. IH never saw the need to install them either. I guess they would patch worn guides on a tractor that gets little use tho.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
