Posted by Hugh MacKay on August 25, 2008 at 02:27:36 from (216.208.58.173):
In Reply to: IH 340 part posted by doug rooney on August 24, 2008 at 14:37:30:
Doug: Go for a matched set of driver and driven gears. They don't last long if you just replace one of them.
The two gears are probably $175. at CaseIH by now. You should be able to get a used set for under $50. It's the same gears on every IH with C-113, C-123, C-135, C-152, etc. Basically every 4 cylinder gas IH built.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and
... [Read Article]
