Re: super c oil leak...
Posted by kelsh on August 18, 2008 at 06:40:43 from (98.243.103.90):
In Reply to: super c oil leak... posted by kelsh on August 17, 2008 at 18:18:44:
third party image
This is the gasket showing the leaks from on top of the gasket.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
