Posted by Janicholson on August 17, 2008 at 18:30:57 from (66.173.50.119):
In Reply to: super c oil leak... posted by kelsh on August 17, 2008 at 18:18:44:
From the factory they have no Valve seals (I like them, but I know that others do not. Perfect Circle style Teflon seals go on my rebuilds. There may be a crack in the head from an oil gallery to the exhaust port. (bad news if so) The head shop should have crack checked the head as a normal procedure. Taking the manifold off might show the location if it is. The plugs should show dramatic oil fouling where the problem is if it is in the cylinder/s, and not a cracked head. The crack may ne all the way to the outside, leaking in that spot. If the manifold was put on well, and flat, it should not leak oil from any place (nor exhaust) Does the oil look burnt when it druels down the block? JimN
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Late 50s early 60s international harvester 560 with cultivator
[More Ads]
