Re: Char Lynn PS problem
Posted by Mike L on August 10, 2008 at 19:33:06 from (66.73.156.9):
In Reply to: Char Lynn PS problem posted by Mike Parks on August 10, 2008 at 16:20:36:
I have char lynn power steering on my 52 M it leaked just like what you have decribed. The one I have has O-rings and washers in each end. The washers along with the O-rings were destroyed by time and use. I replaced them with new O-rings from NAPA. I put two O-rings on each end and discarded the washers did this last winter so far no leaks.
Have hayed with it all summer.
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
