Posted by SuperA-Tx on August 07, 2008 at 12:10:11 from (4.226.54.206):
In Reply to: Super A Battery Box posted by mkirsch on August 07, 2008 at 11:09:02:
The battery box sides are a little differant than the originals but they will work if you ordered both sides. The top is correct from OEM but the little clips on the sides are down further than the original. The top is correct enough to work but you might want to cut a little off the T bolts where it doesnt stick up as far.
A 12V battery will fit in the box just fine. You just need a differant battery. Take the battery box width, length and height measurements and buy a new battery that will fit.
Another problem your going to see is that the battery post is going to be close to the "blind" bolts. Wedge some rubber or wooden wedges in there to make the battery tight.
One other thing you might want to address now is that the battery is going to ride on the lip of the battery box. Cut a 1/4" piece of wood and lay on the bottom to make it flat. Cut it wide enough to fit between the battery lip/side and that will bring it up even.
BTW - I just got a new battery box lid from OEM and put it on this morning. Had one off a 140 on there but the metal clips under the lid kept getting in the way.
Today's Featured Article - Pop's Tractor of Gold - by Gary Teate. My father was a simple man but could repair just about anythin mechanical that was ever made. From the time I was a young boy growing up in Jacksonville, Florida, I would spend a considerable amount of time helping my father repair or rebuild equipment and engines, etc. on our 2 1/2 acre "spread". Pop always dreamed of having more acreage out in the country where he could retire and tinker as much as he wanted and often reminisced about his boyhood days on his grandfathers farm in Montecello,
... [Read Article]
