Re: u-joint replacement
Posted by LenND on August 03, 2008 at 15:27:04 from (216.221.96.202):
In Reply to: u-joint replacement posted by Bob S. on August 02, 2008 at 16:42:27:
Should be able to find a whole used u-joint at wreckers. It wouldn't neccessarily have to be for an M.
That's sounds like one of those weld happy people that shouldn't be let close to a welder.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
