PTO not working
Posted by steve in Texas on July 14, 2008 at 15:13:23 from (75.107.183.22):
I have inherited a 1954 or 55 IH 300 McCormick Farmall with the wide front end. When I first began using it the PTO ran all the time, and I could not turn it off. I was using a shredder and after it began to shear pins, I took off the shredder and now the PTO does not engage. It has the lever on the right side that is supposed to engage/disengage but when it is moved it acts as though it wants to engage but does not. I found a screw adjustment under a small cover on top of the housing above the engagement lever. Moving these does not have any affect on the PTO either way. It sounds as though it is growling inside and I am worried about tearing something up inside so I have not driven it. Any help or opinions on how to correct would be appreciated.
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in. ... [Read Article]
