Re: Sleeve sealing rings on H
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Greg M on March 16, 2000 at 21:43:39 from (205.188.195.22):
In Reply to: Sleeve sealing rings on H posted by Joe on March 16, 2000 at 14:44:11:
I just finished removing the sleeves out of my H and none of them were loose. Before replacing them I removed the "gummy" carbon off of the inside of each cylindar to get them clean and smooth. I then used WD-40 on the bore and the new sleeves and they went right in with just a little tap with a wooden block to get them flush and tight. Maybe your cylindars were honed out too much on a previous overhaul making them a little oversize for the sleeve.
Post A Followup
: Re: Re: Sleeve sealing rings on H
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: John Deere 750 Diesel Yanmar J80TU engine. pistons and rings replaced when discovered crankshaft was bent. 3995 OBO Pictures available upon request [More Ads]
