Tachometer IH 240
Posted by Rob in Ore on June 11, 2008 at 16:33:01 from (206.212.236.2):
I finally decided to do something about my broken tach. I know the cable is shot but I think the unit might be bad too. It is at the shop now. In case the man can't fix it, will a tach for a 300 or 350 work OK? I know the ground speeds might be off some and a diesel tach turns the other direction. Any thing else?
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
