Re: Farmall 350 backing up and stopped...Any Ideas?!?!
Posted by Janicholson on May 24, 2008 at 05:33:06 from (64.83.197.92):
In Reply to: Farmall 350 backing up and stopped...Any Ideas?!?! posted by dirtoutlaw88 on May 23, 2008 at 20:22:59:
The main clutch or the TA clutch are likely candidates for breakage. Either will cause the tractor to stop suddenly. The inner hubs/splines, or drive springs can shear, or the friction material can decompose in an instant and stop all operation.
If the TA (which is a great and useful thing (way beyond the Wizzard of OZ in utility value))has been W/O oil. or broke internally it also can cause this failure. Does the PTO work?
The drive for this comes through the clutch system with different connections.
I think it will require a split to fix it. Some indication might be had from looking in the inspection plate. but splitting is likely. JimN
Today's Featured Article - Major Problems - by Anthony West. Following the aquisition of the two Fordsons to my collection I found that I was struggling to move them about. I had considered the possibility of driving the "F" to and from shows but anything other than local rallies was totaly impractical due to its sedate pace. I had also considered buying a landrover and trailer, but the price of a ... [Read Article]
