Re: H trans gears
Posted by riverbend on May 23, 2008 at 18:36:05 from (208.160.34.253):
In Reply to: H trans gears posted by Calif. Farmall on May 23, 2008 at 16:25:02:
Dan,
If the transmission cover is off, the hard part is done. Get yourself an I&T service manual. The IH manual does cover the trans, but not as well (in my opinion) as the I&T. Both assume that you know what you are doing. A parts book is always helpful. If you are going to keep the tractor, the Operators Manual has a lot of basic information on maintenence, some repairs, and lube capacities.
The tractor does not have to be split to replace the transmission input bearing, but you will get to crawl under it. Check the input shaft pilot bearing and replace it if there is any doubt as to it's condition. Check the rest of the trans and rear end bearings before you go too far. The bearings can run $100 or so a piece for good quality ones.
Surface rust on the gears would not concern me.
Greg
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
