Re: Flywheel - 1940 M
Posted by Janicholson on May 04, 2008 at 19:28:17 from (64.83.197.92):
In Reply to: Flywheel - 1940 M posted by Ave on May 04, 2008 at 19:20:18:
Repeated from page 4..JimN
New pilot bearing, or accurate measurement of the existing bearing to assure it is OK.
New plate, new TO bearing.
Resurface flywheel friction surface, and take the same amount off of the rim where the clutch PP mounts to the FW. this keeps the geometry correct.
Take out three of the PP mounting bolts equaly around (120 degrees apart)use the three to screw into the rear of the PP where there are three holes of correct thread. These bolts release the PP clamping force from the FW. this allows the pp to be released while putting the engine in. after assembly the bolts are re installed in the FW, after putting in the shaft. JimN
the tractor vet
Re: New Clutch Disc for Super M in reply to Janicholson, 05-03-2008 16:30:18
Now when ya reface the flywheel there is a specific hight that the step needs to be cut to . as a lot of places do not know this and this is why alot of clutches slip. the correct step hight should be 1.406 . write that sown so ya don't forgot .
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
