Re: Engine number and serial number
Posted by Jim Becker on April 26, 2008 at 21:05:29 from (71.170.201.34):
In Reply to: Engine number and serial number posted by Mudshot on April 22, 2008 at 19:36:31:
7 31 Q on the block makes it sound like the original. I am inclined to believe that some Super A type blocks were produced to check the machining operations and the good ones were tossed into the production line. Seems like that is what you have. Is the tag on your transmission case literally a tag that is screwed on or is it a tag looking feature cast into the case? My final drive housings have cast in date codes that used "47" rather than the letter "Q".
The earliest A and B tractors had the serial number riveted to the shield below the front edge of the platform. On these early tractors, the seat bracket didn't have the holes for mounting the plate. Maybe your seat bracket came from one of the very early tractors. There could be some history like an aftermarket seat that was later replaced with the seat and brackets from another tractor.
My tractor has the original serial plate on the seat bracket.
Today's Featured Article - Tractor Profile: Oliver 70 Row Crop - by Staff. The Oliver 70 was part of the "Fleetline Series" and was manufacturered from 1937 to 1948. The row-crop configuration could have either dual or single front wheels. The Oliver 70 was also offered in the standard, orchard and industrial configurations. The tractors were sold in Canada. An early advertisement states "Power when you want it - power when you need it - power to help put in crops when field conditions are right and time and help are limited. That's the power you'll find in an Oliv ... [Read Article]
