Re: Rim paint for Farmalls
Posted by RustyFarmall on April 18, 2008 at 04:59:14 from (209.152.78.71):
In Reply to: Re: Rim paint for Farmalls posted by IHKYguy on April 18, 2008 at 03:40:19:
The paint is a very bright silver color. It may actually have aluminum in it. I think you will find it on the same shelf as where you found your other paint. There is no description of color other than "aluminum". Be advised that "aluminum" paint is somewhat thin, and has a real tendency to run if applied to heavy. Several thin coats applied with some drying time between each coat would be the correct procedure.
I buy it in quart cans, and apply it with a good quality soft brush. Experiment a little and eventually you will know how to get the final results with absolutely no brush marks.
Today's Featured Article - Major Problems - by Anthony West. Following the aquisition of the two Fordsons to my collection I found that I was struggling to move them about. I had considered the possibility of driving the "F" to and from shows but anything other than local rallies was totaly impractical due to its sedate pace. I had also considered buying a landrover and trailer, but the price of a ... [Read Article]
