Posted by glennster on April 11, 2008 at 07:29:41 from (76.223.243.231):
In Reply to: farmall difference posted by mhny on April 11, 2008 at 07:23:13:
the a has a wide front, b, narrow front. same engines and trans, same hp. b has wide left rear axle, a, narrow lt rear axle. both handy little tractors, real good with a belly mower. pricewise, i"d guess the a would bring a little more with the wide front.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Late 50s early 60s international harvester 560 with cultivator
[More Ads]
