Re: Whats a famall M worth?
Posted by DCW on March 21, 2008 at 17:35:39 from (156.34.206.247):
In Reply to: Whats a famall M worth? posted by Michael price on March 21, 2008 at 08:29:21:
If its as bad as you say,offer $200 for it,no more.You've got to assume that the engine is no good,the tin is no good,and possibly the tires and rims are no good.If you were to fix the tractor,likely you'd have to replace these items,meaning if you wanted to part it out,this stuff is scrap,not leaving much left to sell.
There comes a time that even if you were given the tractor,that is simply not worth the money you'd sink into it to ''fix it up''.Some tractors are simply too far gone.If it once belonged to your family,and it had a sentimental value to you,then you'd fix this tractor regardless the cost.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
