Re: farmall bn- bearing code help
Posted by El Toro on March 03, 2008 at 14:47:22 from (64.12.116.73):
In Reply to: farmall bn- bearing code help posted by GERRY BN on March 03, 2008 at 12:40:49:
You need to do as Scotty suggested on having the
crankshaft measured for wear. Clevite should have Std size and any undersize from .002" (.050mm) to .030" (.762mm). I had my auto machine shop supply my bearings on a Farmall A. All were .002" (.050mm) (undersize. The shaft didn't look too great, but only needed to be polished. Hal
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
