Re: Super A valve cover gasket thickness
Posted by K-Mo on February 23, 2008 at 04:34:34 from (65.169.189.2):
In Reply to: Super A valve cover gasket thickness posted by SteveNH on February 22, 2008 at 10:14:12:
Unless you enjoy the challenge of making your own, you can buy gaskets from NAPA or O'Reillys for less than $10.
K-Mo
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
