Re: Leaks
Posted by Janicholson on February 14, 2008 at 06:13:06 from (199.17.6.122):
In Reply to: Leaks posted by Kristof on February 14, 2008 at 06:00:54:
It is a good product, Subaru uses it (or branded similar) as a practice in some engines. It will still work well, I would run it with cardboard over the radiator so it gets up to toasty temps for an hour. Driving around is also good. JimN
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
