Re: Comfort cover
Posted by Hugh MacKay on December 24, 2007 at 02:38:56 from (216.208.58.106):
In Reply to: Comfort cover posted by Jimer on December 23, 2007 at 16:39:33:
Jimer: The other have good ideas, however a Utility type tractor can be done and be effective for very little money. Just run about 3' wide material (preferably cavvass) back each side from side of grill to middle of fenders, then place one across the top so heat can't escape upward until it gets to you.
Make provission for rolling this material back from grill. It will get too hot in the seat anywhere above 10F. I used to do this with Farmalls, however the cheapy is much more effective on a utility, as your sitting lower.
Having said all of this, a Heat Houser for a utility is probably a lot less money than for a farmall. I remember once, spending the extra money for and official heat houser complete with plexi glass windshield and a canvass flap one could close behind him. This was a Farmall 300, and the first provission we had to add for plowing snow was a place to put your gloves or mittens. Basically, plowing snow bare handed down to 0 or -10F, plus one was warm in there. They have one downfall if it's snowing, heat melts all the snow coming in from the top, thus you can get quite wet, if your out there long.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c ... [Read Article]
Latest Ad: John Deere 750 Diesel Yanmar J80TU engine. pistons and rings replaced when discovered crankshaft was bent. 3995 OBO Pictures available upon request [More Ads]
