Steve: As gene said, the end of the shift lever is worn. You'll have to remove it separate from the transmission top, build it up so it snugly fills a notch on one shifting rail. It's best to build a bit oversize then grind enough to make it shift smoothly. Secret is get it so it can't get out of shifting rail notch until rail is at neutral.
There are also detent balls and springs on each rail, however those usually don't give much problem. If they are bad the symptom is poping out of gear usually under heavy load. Your best approach is remove the top cover, then remove lever from the top for rebuilding. After you remove the lever try moving those shift rails, you should be able to feel the detent balls activate. It's worth investigating while you have the top off.
Today's Featured Article - The Day Mom Drove the 8N - by Brian Browning. My Dad was wanting to put in a garden but couldn't operate the 8N and handle the old horse drawn plow he had found and rigged up to use with the tractor. Well, he decided to go get Mom out of the house and have her drive the tractor while he walked behind the plow. You got to understand that while my Mom is a hard worker who will always help whenever she can... she had never operated farm machinery before that day. Dad got her out there, explained how the clutch was the same as in our o
... [Read Article]
Latest Ad:
[More Ads]
