Re: H starter problems
Posted by John T on December 06, 2007 at 18:44:23 from (66.244.83.147):
In Reply to: H starter problems posted by Illinois Farmall on December 06, 2007 at 15:55:34:
For starters (no pun intended), hooking up a starter say in a vise etc for a bench test n just seeing/hearing her spin "okay" dont really tell ya all that much cuz theres no load. Of course, however, when in the tractor she ought to spin fast enough to engage the bendix.
Okay, if the starter is reallyyyyyyyyyy good ???? and the starter switch is reallyyyyyyyyy good????????and the battery is reallyyyyyyyyyyyy good???? and the cables are reallyyyyyyyyy good?????? A BAD STARTER TO FRAME GROUND IS ABOUT ALL THATS LEFT Clean n shine n wire brush the mating surfaces n starter mount bolts etc
OTHER ISSUES
If it has an external push switch versus a starter saddle mount you can by pass jump around the switch to insure thats still not the problem.
Even if cables look good to the eye externally, they can still be burned n carboned n resistive underneath or under the crimp, TRY JUMPERS OR DIFFERENT CABLES
If the battery grounded is to a thin or rusty wimpy sheet metal object, re ground to a clean main to frame bolt n try it.
Make sure the battery is reallyyyyyyyy good n full charged??????? Have it load tested
Remove, clean n wire brush, n re attach each n every battery n starter n switch n ground connection again
John T
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
