Re: Can someone help me identify this IH tractor...Thanks!
Posted by D Slater on December 04, 2007 at 15:12:38 from (72.65.140.68):
In Reply to: Re: Can someone help me identify this IH tractor...Thanks! posted by Mark Peters on December 04, 2007 at 15:01:27:
Mark, easy tip offs are the serial # plate on the right side instead of left like a 400 and the serial # is higher than 350 went to.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
