Posted by perrycountyfarmalls on November 02, 2007 at 03:43:08 from (71.72.111.89):
In Reply to: 300 utility Front Split posted by Dustin Bench on October 31, 2007 at 18:06:11:
Hello,
Had the same problem once on my 350d. The "plate" that bolts to the engine came loose, not the cast bell housing bolts. So that meant splitting the tractor. I put in new grade 8 bolts and lock tighted them. Mine coming loose was a result of the previous owner doing a poor re-assembly job after putting in a T/A. I found many, many loose bolts on my way in there. My tractor was starting to "chatter" under much of a load due to the sagging in the middle. It sounded like a throw out bearing making noise when you pushed in on the clutch.
Today's Featured Article - Tractor Traction - by Chris Pratt. Our first bout with traction problems came when cultivatin with our Massey-Harris Pony. Up till then, this tractor had been running a corn grinder and pulling a trailer. It had new unfilled rear tires and no wheel weights. The garden was already sprouting when we hooked up the mid-mount shovel cultivators to the Pony. The seed bed was soft enough that the rear end would spin and slowly work its way to the downhill side of the gardens slight incline. From this, we learned our lesson sinc
... [Read Article]
Latest Ad:
[More Ads]
