Re: farmall hyd pump
Posted by CNKS on October 16, 2007 at 14:04:20 from (216.144.104.128):
In Reply to: farmall hyd pump posted by dave aeschliman on October 16, 2007 at 13:49:50:
Next to the gearshift lever. The transmission, rear end, hyd, and TA all use the same reservoir. Use HyTran. Level plug is on the left side of the tranmission housing.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
