Re: governor spring broke
Posted by MJF on October 14, 2007 at 19:06:08 from (4.90.223.176):
In Reply to: governor spring broke posted by S M Himrod on October 14, 2007 at 15:50:51:
We don't have a C so I don't know but for my H I went to tractor supply and got one that match up off the spring rack. Mike
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
