Re: Farmall B-carb
Posted by teddy52food on September 12, 2007 at 18:18:47 from (204.73.107.177):
In Reply to: Re: Farmall B-carb posted by Dave H (MI) on September 12, 2007 at 14:16:54:
Have you tryed using the choke with the gas shut off? It may need a full choke for one or two compressions with the switch off. then open the choke, turn on the ign & hit the starter. It should pop right off. Did you check the float & make sure there is no gas in it? If the float is heavy with gas ,the fuel level will be too high before the needle can shut it off. Take the drain plug out of the bottom and put a barb & clear line on. Loop the line upwards, turn on the gas & see where it levels out. If it slowly rises ,the needle is leaking. Keep us posted OK?
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
