Posted by Janicholson on September 08, 2007 at 06:52:19 from (66.173.50.72):
In Reply to: farmall H posted by Russell boseck on September 08, 2007 at 05:46:19:
Ideas: This is almost always fuel related The carb has several circuits from Idle to full power The idle circuit can work when the others are plugged up A fuel supply that is partially blocked can do exactly that
The first fast step is to adjust the load needle one half turn out in several steps to see if it going to richen the mix. Look at the parts diagram for the tractor at caseih.com to locate the needle. (you need a manual as well.
1) Open the drain on the carb with a can under it, and the fuel valve at the tank open. If it comes out like it was running through a soda straw for more than a minute (time it, and use a big can) the supply is fine. 2) Take the bowl off of the carbm and clean all junk out of it, and look at the main jet to see if it has material plugging it up. Use carb spray on the underside to give it a chance to work. If these efforts don't help. The carb needs a kit and soaked to clean it.
Ignition can be a part of the problem, but in this case I doubt it. Good luck, JimN
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
John Deere 750 Diesel Yanmar J80TU engine. pistons and rings replaced when discovered crankshaft was bent. 3995 OBO Pictures available upon request
[More Ads]
