the manifold & extension on my SA were "grown" or rusted together too. I hack sawed it off about 1/8" above where it threads into the manifold. From there, I took a punch, and tapped inward until I got some of it broke loose from the threads in several places. I let it soak overnight with penetrating oil, but still couldn't twist it out. I finally got out the torch, and heated the pipe part up enough to peel it out of there. The pipe was thin enough to quickly get red hot & soft, without heating the manifold enough to bother it.
Today's Featured Article - Product Review: JB Weld - by Staff. JB Weld is basically an epoxy glue that does an exceptionally good job of bonding to cast iron and steel along with several other materials. As I mentioned, it is so common that I have yet to buy a tractor that did not have JB Weld used somewhere. It is sometimes used so well you can't tell its there and other times used as a sloppy quick fix. Finding where and how it can be used correctly is key to whether you are using it as an "inelegant hack" or an integral solution to difficult and expens
... [Read Article]
